Group Buy # 2 Arospeed Adjustable Cam Gears
oooo, cant believe I didnt see this earlier.
interested in a set for rb26
whats the rate and lead time at now? not fussed on color, if the buy is over and anyone wants to offload thier set PM me.
Edited by Betz
  • Replies 223
Posted Images
Guys it will take about 12-16days.
Gears will be ordered 2 morrow.
We should recieve them this week hopefully, can you confirm this for us please r33kid
Cheers
Edited by XZLA.8
Yeh should be late this week early next, if everything runs smoothly
Cheers
cam gears have arrived in australia and are currently in customers, once i get them in my hands ill advise.
That is great news.. :)
I hope they get through customs alright though.. :)
The cam gears are in my hands now, these will be getting despatched from friday.
Thanks to all that participated.
Another successfull GB.
When you recieve can you leave me trader feedback.
for sure no probs... have hks step 1 cams going in at the same time so car should gain some good hp!
Thankyou.. for organising the groupbuy..
I will definately add to yuor trader rating when I recieve my set of Blue Cam gears to suit an RB20DET..
Thanks again.. it was greatly appreciated.. :P:D
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
