Group Buy # 2 Arospeed Adjustable Cam Gears
r33kid
  • Replies 223
Posted Images
i can organise another gb but it all depends on interest.
Ok put me down as number 1, anyone else keen? :)
Yeah I'll most probably be interested in another groupbuy.. will get multiple pairs this time ;)
Also, how're we going with sending out of the Gears? Any news.. just curious..
The cam gears are in my hands now, these will be getting despatched from friday.
Thanks to all that participated.
Another successfull GB.
When you recieve can you leave me trader feedback.
Probably should read all the posts mate..he's clearly stated a friday dispatch.
Yeah I read that, but he could of been busy.. I know not everything I plan to do is done on time.. other more important thing just pop out sometimes??
12 members gears were sent today, another 14 members gears will be sent out 2morrow and more the following day, just trying to find some spare time.
That's alright..Thanks for organising this groupbuy.. if you have another one in the future, let me know as I am interested in buying a few more sets..
Do you think it would matter putting these on now if i'm not gonna get a dyno re-tune for a while just yet? I know not much difference will be noticed, if at all until its tuned. But could it actually be worse to have them on untuned for a while?
Any help woud be much appreciated guys, thanks.
Edited by R3LOAD
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
