  • Replies 175
Posted Images
Link to CAMS release
Australian Motor Racing Legend Dies in Targa West
CAMS Media Release
8 Sep 2006
With great sadness CAMS advises that Peter Brock, Australian motor racing legend, has today died in an accident during Targa West, a tarmac special stage rally being conducted near Perth, Western Australia.
The accident occurred at approximately 11:50am WST. The co-driver has been conveyed to hospital in a stable condition.
The Confederation of Australian Motor Sport (CAMS) will conduct a full investigation into the incident. In the mean time, CAMS and event officials are working with the relevant civil authorities.
On behalf of the motor sport community, CAMS offers its sincere sympathy to Peter鈥檚 family and many friends.
CAMS will issue additional statements as further information becomes available for release.
Colin Osborne, CAMS President, will be holding a media conference at the South Australian Office of CAMS at 3.30pm today.
For more information regarding this release please contact:
Colin Osborne, President, Confederation of Australian Motor Sport
Tel: 0418 976 517
i find it very strange that both steve urwin and peter brock died doing the things they are considered to be legends at. the only thing to be said is that he died doing what he loved, as did steve. It kind of helps a little i think.
very sad!!!
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
