Hi all,
Just had a quote on my parents car for repair to the air con. Its not puttin any cold air out what so ever. Here is the list on what needs to be done and prices. If anyone can help out on what they think the prices and parts are worth that would be great. Just trying to get a second opinion.
* EF Ford Falcon
* removethe dash and replace evaporator and to fit a reconditioned compressor, tx valve and reciever drier and fully flush system
* Labour 9 hours @ 74.55 = 738.05
* Recon Compressor $ 494.00
* Reciever Dryer $30.00
* TX Valve $55.18
* System Flush $80.00
* Regas and evac $90.90
* Heater hoses $30.00
Evaporator $145.45
Tx valve and flushing of system are required for warranty and incase of metal particles in system
GST $159.65
TOTAL $1756.13
***If anyone can either say yay or nay on these prices or mention that we are getting shafted that would be awesome.
Thanks for your time
M
https://www.sau.com.au/forums/topic/133529-air-con-quote-a-little-over-the-top/
I Had very similar work done to my air con unit as it was stuffed. Had all the things
you had done except for the evaporator and hoses (not sure what the evaporator is for?).
Anyway they had the car for two days and charged me $1050. :O
ok what is the actual fault?
ceized compressor?
leaking evapourator?
leaking tx?
drier gets replaced when compressor is done to have warranty but usually when you replcae the drier we recommend you replace the condensor which is infront of the radiator (removal of bumper which is about 1.5 to 2 hours ) to replace the evapourator you need to remove the entire dash board, center console and heater box which takes between 4 - 7 hours depending on how mucn of a PITA it is being!
have the done any checks of any sort ie with a/c guages? temporary regas with leak detectant dye to locate any leaks?
ef & el falcons are prone to leaking condensors along poor welds on let end tanks when we replace the replace the compressor & Drier as well, because of the change in a/c perfromance which if you don not replace the compressor you risk compressor failure which brings you back to square one because of debris being pumped around the system at my
work we charger about
1200 i think i cannot remember but thats aroundish
for a condensor and compressor replacement.
evappourator and compressor will be around the 1500- 1600 because we would also replace the condensor to avoid any comebacks. it is strange they want to replace the tx valve. we generally clean and re fit them. unless they have been working incorectly or look shabby we then only replace it.
to have the system flushed should really only be done if compressor has failed and there is deffinent evidence of deris.
i find it strange that they havent mentioned replacing the condensor as they cannot be flushed due to the fact they are parrallel flow ie have end tanks. debris will sit any where in them and if you cannot pass flush through them they will not ever be clean and eventually will cause failure of the compressor
any ways this is my opinion only but i believe you are being taken for a ride because they do not seem to have a idea of the type of a/c system
cheers!
Thanks skybee, thats an awesome write up, i have passed that onto my parents and by looking at your reply i think a second opinion will be a good idea.
Cheers
Matt
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
