looking to get an idea on how the hand brake works at the calipar on an r32 skyline.
basically wanting to see what needed to be done to get it working on an r31 skyline...
things like:
is it cable or some other system?
is it a part of the calipar?
Cheers, Matt...
Edited by rsx84
https://www.sau.com.au/forums/topic/133553-hand-brake-set-up-on-an-r32-skyline/
well the first thing you need to find out is the hole in the centre of the drum brake have a greater diameter than 72mm? the yellow line is the hole you need to measure, note that is a HR31 drumbrake not a R32 drumbrake
if it isn't greater than 72mm it won't fit on your diff so back to square one and try and find something else. once you find a suitable drumbrake next question do you own/have access a band saw with a metal band on it, MIG welder and have all the parts needed ie drumbrake, calipers and rotors? if not then you will need an engineer to do all this and it will cost lots of $$$, or if you are in brisbane i am half way through putting HR31 drumbrakes and R32 GTR calipers on the rear of my R31, so you can drop around and see what has to be done.
to bolt up the drumbrake will require you to cut the bracket off that holds the axle to the diff and make 2 new brackets, 1 for the drumbrake to mount onto the diff and the other 1 for the R32 GTR caliper to mount onto also you can't use the R31 caliper mount as it has a caliper spacing of 100mm and the R32 GTR caliper has a spacing of 117mm.
thanks for the info guys, the reason i ask is i got the rear brakes and rotors as a package when i bought the fronts, been specking to a bloke from the ozdat forum, he offers a package for the datto 1600 for around $600 so thought id look into what can be done for the r31, with the package they offer they have a seperate handbrake system, have a look....
http://datsport.com/Datsun_510_R32_rear_di...nversion_A.html
this would be more of an option for the HR30/31 with the IRS rear end i'd say..
Edited by rsx84
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
