Hey guys, i dont know alot about skyline's i just got mine a few weeks ago.
I have been told that it is not possible to run an external wastagte because R33 skylines Gtst's have an internal wastegate?
I have taken some pictures with the heat sheild removed and it looks likes the wastegate is external to me and is running back into the exhaust, would i just pay for somone to remove the pipe going into the exhaust seal the hole and make a larger pipe coming out so i get the flutter noise?? or is there alot more to it then i have been told... :) can somone give me a rundown on how this works and what i need to do?
Thankyou
http://img148.imageshack.us/my.php?image=0909061312zb0.jpg
http://img245.imageshack.us/my.php?image=0909061311xf6.jpg
Edited by Woody1
https://www.sau.com.au/forums/topic/133579-external-wastegate-possible/
Thats an internal wastegate, this means that the "flap" that controlls the boost pressure is in the turbo exhaust housing, its just that your dump pipe has a separate pipe for these gasses, why would you wast to run an external gate, it is possible, although the whole job would be fairly expensive(probably $1200) and gain you no power, and maybe a defect too if you have it venting to the air.
the wastegate and dump have nothing to do with flutter or "cooler noises". you should do some reading on what wastegate is and how it works and why an external wastegate is pointless on the stock turbo. the flutter is known as compressor surge, do a search on it. its often listed as flutter and is nothing more than air being chopped on the compressor wheel, causing damage
I have an external wastegate, but I also have a bigger turbo, and a modified exhaust manifold to suit. So yes, it's possible.
But as everyone said, do some research (use the search function, and google). I don't really think you understand what a wastegate actually does.
Thankyou guys no i have no idea and i am not very good with computers either lol, i have seen a few cars using a system that makes a flutter noise that causes no damages but i dont know what it is called, maybe i am using the wrong name, but thankyou all the same for your helpful information.
Try putting a pod filter on it this should give you the desired result, if not then you will have to fit an adjustable recirculating blow off valve and set it up with some extra preload. Backspin is what YOU want to hear, and this is the way to achieve it.
unfortunatly despite what you have been told, the noise you are wanting to hear IS compressor surge and even in its minimalist form causes damage to your turbocharger. unnecessary stress on the internal components of your turbo charger especially on the skyline turbos in not what you want and really defeats the purpose of blow off valve which is designed to rid the system of compressor surge and so on
If you want the flutter noise get a pod filter and block off your bov. This will cause the air to go back out through the compressor getting chopped up and then back out the pod. This will give it the flutter noise, no one has really proved itll damage your turbo, but no one has proved otherwise.
Some older turbo cars eg HR31 skylines etc didnt come with a bov from factory and ran fine, so Id say very minimal effect on the life span of the turbo if any at all.
I bet someone told you it was 'wastegate flutter' and thats why you want an external wastegate :) , if so hit them over the head.
Go to www.howstuffworks.com look up turbos and wastegates on there, it gives a very easy to understand basic explanation of how it all works. Great website for learning the basics.
Edited by Rolls
A dealership told you that it was wastegate flutter?
Youd think that someone that deals with cars would at least have a clue how they work.
I disagree here. Dealers usually don't know anything. Same as the "guys at super cheapbarn".
Mid 90's it was always "the guys at harvey norman said x about my computer".
I went down to the specialist and he said it is imposiable to get this noise but i think hes full of S&^T because i have a mate that has a external wastegate coming out of his turbo that makes this noise, but if i have to replace a turbo to get it i say no thanks =O ill just keep my skyline and buy a gtr in a year or so.
Did you even read what we said? its not the wastegate, its from having no bov and a pod.
Its frustrating when you tell someone something and they completely ignore you.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
