Im looking at buying (not gfor me) a set of four p1s. Mint condition, 16x7 and 8s. (staggered). with 225s and 245s. White.
I know this isnt a stagea topic, but i know you guys, and im sure a couple of stages on here are sporting p1s. Whats a set like this worth?
cheers
rob
need a preeeeeetty quick answer, just a ballpark figure
Edited by qikstagea
https://www.sau.com.au/forums/topic/133600-buddy-club-p1s/
cheers
rob
around $420 a piece according to the internet...
http://www.modyourcar.com.au/product_info....roducts_id=4216
https://www.sau.com.au/forums/topic/133600-buddy-club-p1s/#findComment-2482506
Apparently there are cast versions of the P1's now available. They won't be as light as the original forged versions, but they will be cheaper.
Standard P1s were always cast.
It was the QF version that was forged.
They also have the P1 Racing II and P1 Racing SF in their range and both these are cast too.
https://www.sau.com.au/forums/topic/133600-buddy-club-p1s/#findComment-2483025
Jeez, James - someone in the NSW Whorethread kinda joked that you were EVERYWHERE on these forums, but I'm noticing it becoming more and more true each day I spend here...
https://www.sau.com.au/forums/topic/133600-buddy-club-p1s/#findComment-2483099
i paid $1600 for a set of p1 racing 1's 2 1/2 years ago, 17" x 8 and 17" x 9, i'd say the 16" would be cheaper still, i think www.powerplayimports.com are the aus licence holder on buddy club, if you went P1 Racing II's ones with dish, you may as well double the price...this is with out tyres
Matt..
https://www.sau.com.au/forums/topic/133600-buddy-club-p1s/#findComment-2493467
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
