  • 1 year later...
hey, 1st post (yay lol)
anyway, I've just bought a 1993 r32 gts4 sedan and its still standard off-road ride height, was just wondering if i get some GTR adjustable coilovers if they will fit straight into the gts4 being a sedan?
any help is appreciated?
PS: sorry for using an old post
Nope, rear shock mounts are different.
Cheers
gary
Have a pic of the 4dr you bought? Gts4 r32 sedans are rare. I've got one too.
Have a look under the car, If the rear lower shock mount is a round eye, then it won't.
My car had stock gtr suspension on it, but no telling wether it had been changed previously. I haven't seen a gts4 without gtr matching parts, but they are a heinz57 sort of car so anything is possible.
Haven't got a picture of it at the moment, was gunna take some after i washed it but decided id de-spoiler it first lol and the bungs i had for the spoiler holes dont fit. will take some when i get that sussed
also do they make suspension specifically for the gts4 sedan? coz i definitly dont want to leave it as is coz at the moment u can nearly limbo underneath it
Ohh and do GTST exhaust fit onto GTS4's? Coz the one its got at the moment is 2x3" piping into 2 big bores, not my sortve look and has limited backpressure and one of my mates cousins has a 3" gtst exhaust for sale
Edited by GTS4onP
Whoo! Another 32 four door GTS-4 owner. :domokun:
You can use GTR coilovers. I've got GTR ones in my car at the moment.
You should be able to use GTSt exhausts on your car, the only difference between GTS-4's and GTSt's is the 4wd system.
Edit: The rear lower shock mounting is the fork style (on my car at least).
Edited by adam-__-
So my adjusties turned up today
the front say GTR so pretty sure they'll fit
but rears say GTS so I'm unsure, have emailed the guy and he reckons they fit but im still unsure
ill whack some pics up so you guys can confirm, dont want 2 b left with 2 shocks that wont fit and im unable to return them or someting stupid
Cheers
PS: 2nd pic is the rear lower mount
most likely, hes a pic of the other 1 (front or rear, u tell me lol)
yea, so if they were vice versa would they fit?
lol and please no comments on the mad as elephant bedspread on the spare bed haha
I'm fairly certain that the shocks in my car were longest on the front, also that no skyline has a fork for the front shock lower mount, and that in the last pic, there is a big R on the sticker..
Still the easiest way to tell is to get on your back and look under the car at the shock mounting points.. or pull a wheel and it will be obvious.
Just take a look under the rear of the car. You won't even need to jack it up to be able to see the lower mounts. That one on the left in the pics will be the rear and the one on the right will be the front.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
