1996 R33 GTS-T M-Spec Finished in Artic White with 81233 on the clock at the moment.
Features:-
M-Spec Front Bar with Extra Lip Section (Factory Fitted)
PIAA Low Beam "Blue" Headlamp Bulbs
Whiteline Front Strut Brace
Cusco Rear Strut Brace
Rear "Skyline" Iluminated Beaver Trim (Factory Fitted)
the "E" doesn't work unfortunately but should be an easy fix.
Remote Central Locking (Factory Fitted)
R34GTT Wheels
Goodyear Eagle F1 Z rated Tyres
Whiteline Lowering Springs On Standard Shocks
Whiteline Urethane Front Radius Rod Bushes
5 Zigen Cat back Exhaust
Nismo 300KMH Speedo (currently with 2578 Kays on it)
Speed Limiter Remove Electronically (Not Sure Of Brand)
Cusco Brake Master Cylinder Brace
DBA Gold-Line Drilled and Slotted Front Discs
EBC Green Front Disc Pads
DBA Slotted Rear Discs (Not Fitted)
EBC Black Rear Disc Pads (Not Fitted)
UAS Clutch Kit (6 Finger Cerametalic Clutch Plate)
3 Point Imobilizer
Kenwood Head Unit with Single CD
Blitz Turbo Timer
This car is our weekend bit of fun, it's done very little city work, never used as work transport, has mostly been used for long country runs. It's never done a burn out or anything like that. We are the 1st owners in this country.
It has been regularly maintained by Mazda Australia's 12 Hour/Targa Chief Mechanic every 10,000 kilometers with me doing the intervals in between.
Still running Standard Boost!!!!!.
This car has Never ever wanted for anything,,,if it needed something done,,,IT got DONE.
I personally have done heaps of little things all around the car and an inspection will not disappoint.
Asking $27500 NO Offers.
If you are interested,,, feel free to ask any questions you like or simply PM me...
Neil.
https://www.sau.com.au/forums/topic/13361-r33gts-t-series-2/
Mark,,,hope you got the pics okay,,,sorry thats all I have at the moment.
I also have 2 Standard Wheels with Brand New Falken Tyres, Standard Speedo with 78655 kays on it, New Genuine Rear Disc Pads, Original Front Discs, all Receipts and Log Books. All will go with the Car.
Neil.
https://www.sau.com.au/forums/topic/13361-r33gts-t-series-2/#findComment-258891
Please,,,to the guy's that pm'd me about selling parts seperately,,,sorry the answers no at this stage...
Her new owner will appreciate her all the more just the way she is.
If I have to trade her in,,,,then I might reconsider.
Neil.
https://www.sau.com.au/forums/topic/13361-r33gts-t-series-2/#findComment-267372
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
