1996 R33 GTS-T M-Spec Finished in Artic White with 81233 on the clock at the moment.
Features:-
M-Spec Front Bar with Extra Lip Section (Factory Fitted)
PIAA Low Beam "Blue" Headlamp Bulbs
Whiteline Front Strut Brace
Cusco Rear Strut Brace
Rear "Skyline" Iluminated Beaver Trim (Factory Fitted)
the "E" doesn't work unfortunately but should be an easy fix.
Remote Central Locking (Factory Fitted)
R34GTT Wheels
Goodyear Eagle F1 Z rated Tyres
Whiteline Lowering Springs On Standard Shocks
Whiteline Urethane Front Radius Rod Bushes
5 Zigen Cat back Exhaust
Nismo 300KMH Speedo (currently with 2578 Kays on it)
Speed Limiter Remove Electronically (Not Sure Of Brand)
Cusco Brake Master Cylinder Brace
DBA Gold-Line Drilled and Slotted Front Discs
EBC Green Front Disc Pads
DBA Slotted Rear Discs (Not Fitted)
EBC Black Rear Disc Pads (Not Fitted)
UAS Clutch Kit (6 Finger Cerametalic Clutch Plate)
3 Point Imobilizer
Kenwood Head Unit with Single CD
Blitz Turbo Timer
This car is our weekend bit of fun, it's done very little city work, never used as work transport, has mostly been used for long country runs. It's never done a burn out or anything like that. We are the 1st owners in this country.
It has been regularly maintained by Mazda Australia's 12 Hour/Targa Chief Mechanic every 10,000 kilometers with me doing the intervals in between.
Still running Standard Boost!!!!!.
This car has Never ever wanted for anything,,,if it needed something done,,,IT got DONE.
I personally have done heaps of little things all around the car and an inspection will not disappoint.
Asking $27500 NO Offers.
If you are interested,,, feel free to ask any questions you like or simply PM me...
Neil.
https://www.sau.com.au/forums/topic/13361-r33gts-t-series-2/
Mark,,,hope you got the pics okay,,,sorry thats all I have at the moment.
I also have 2 Standard Wheels with Brand New Falken Tyres, Standard Speedo with 78655 kays on it, New Genuine Rear Disc Pads, Original Front Discs, all Receipts and Log Books. All will go with the Car.
Neil.
https://www.sau.com.au/forums/topic/13361-r33gts-t-series-2/#findComment-258891
Please,,,to the guy's that pm'd me about selling parts seperately,,,sorry the answers no at this stage...
Her new owner will appreciate her all the more just the way she is.
If I have to trade her in,,,,then I might reconsider.
Neil.
https://www.sau.com.au/forums/topic/13361-r33gts-t-series-2/#findComment-267372
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
