Hi guys, the other day i put a HKS 2540 on my RB20 R32 and got it going :) I haven't got the wastegate connected so it boosts of its head :D When she gets to about 13-14 psi it coughs and splutters bad like its got a boost cut??? my question is does the standard computer have a boost cut or something of the like? God i can't wait till my Power FC turns up :D And also the new HKS turbo doesn't have a wastegate line fitting on the compressor housing like the standard turbo where should i connect my new wastegate pressure line?? Any help is greatly appreciated :)
https://www.sau.com.au/forums/topic/133623-overboosting-stock-computer/
The standard computer does not have a boost cut and you dont want to get your wastegate signal from the same point as the bov or boost gauge signal.
You need to take the wastegate signal from before the throttle body, not after, the closer to the compressor outlet the better. Get a nipple brazed into the compressor outlet pipe.
I'd suggest that the missfire is due to slightly rich mixtures, 15 year old coils, and plugs (and gaps) not suited to the level of boost you are running.
Cheers guys, I tried what RB SANDY said and disconnected the blow-off valve, works well by allowing the extra pressure to escape.
BHDAVE thanks mate you confirmed what i was thinking, i need to remove the compressor housing and either tap a thread for the nipple or get one braised on. Cheers guys your input is much appreciated :)
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
