Yeah thanks for the responce. I knew I was driving a dunger but I didn't know how dunged! I guess I better reserve judgment until I drive a good example. I have driven a Gtr with 200,000k's on th clock and it was still great, I spose it was owned and serviced by someone with a bit more mechanical sympathy.
Anyway My Gtt's sold and I've ordered a Gtr :D
It would have been nice to own a classic BMW though. A new one is a little more than I'd want to spend!
https://www.sau.com.au/forums/topic/133630-m3/page/2/#findComment-2479093
I thought E36 M3s were now considered slow - until this one whipped my arse around the track:
but then again, you would be surprised what(well driven) low powered cars can whip skylines arses around tracks!
in independant testing the latest m3s do mid 13 quarter miles, so dead stock they are quicker than GTTs but not R34 GTRs, and IMO not classed as a supercar("normal" supercar) performance wise, but are in most other ways.
Edited by siksII
https://www.sau.com.au/forums/topic/133630-m3/page/2/#findComment-2479265
my neighbour used to have a BMW m5 2003, that thing sent out sonic booms when his wife was reversing at 3 k an hour im not sure what motor it had but it sounded like nothing i have ever heard, not meaty just perfectly sounding...i dunno hard to explain
f**k it was mint i offerd to clean his car but he didnt let me , spewin
https://www.sau.com.au/forums/topic/133630-m3/page/2/#findComment-2480369
I did a M3 driver training day around philip island in brand new (4,000ks old) m3's... awesome car, so nice, well balanced.. it certainly doesn't put you back in your seat and doesn't 'feel' quick but thats because it's so smooth. a quick check of the speedo and i then realised i was going fast.
I'd have(want) one as a daily, but not as a track car, can't beat a well sorted out GTR on the track.
https://www.sau.com.au/forums/topic/133630-m3/page/2/#findComment-2480639
Good cars, you drove a 10 year old example with the S50B32. Hunt around they come in 3.0 ltr and 3.2 ltr guise with the 3.2 having the double vanos, better sump and a few other bits and pieces. Some people think the 3.0 ltr is a better engine for playing around with, but all the serious hitters world wide use the 3.2. The fastest BMW in Australia runs the same engine you drove with a turbo.
They are a great car, a bit of fun. From the factory they are geared far to long, especially the E46's so shorter ratio diff gears should be on the cards with anything that has a 6 speed in it.
Definantly capable, and a good bit of kit.
https://www.sau.com.au/forums/topic/133630-m3/page/2/#findComment-2480718
Yes. Very. Mate just bought 1. 2nd hand. 76k kms, GPS, sunroof, 19" rims, metallic black. Bought it for 78k.
The only place good E46s are going for 90-120k are from a dealer.
' date='11 Sep 2006, 08:27 PM' post='2481951']
Not quite!
An high standard used E36 M3 goes for about $35k-$50k and an as new used E46 M3 are between around $95k and $120k.
https://www.sau.com.au/forums/topic/133630-m3/page/2/#findComment-2503037
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
