I have read up on a few other forums that by using Z32 fuel filter has less restriction which "apparently" makes the car little more responsive... there is a definite size difference between the OEM and Z32 filter but how true can this be?
Picture courtesy of Alex Au
Regards,
Sarkis
https://www.sau.com.au/forums/topic/133640-which-fuel-filter/
Fuel that is pressurised around 50psi? I doubt that would make any flow difference? No idea... but unless you're running a fairly worked car, I doubt you would get ANY benefit.
As a side-note, the bigger one won't fit into the stock bracket on the R33.
