hey all
i have a gt35 journal bearing turbo 700hp rated
front housing is 0.70 A/R with 58mm wheel 4" inlet
rear housing is a 1.06 A/R with 62mm wheel and is a t3 split pulse flange with 3.75 v-band outlet
currently has an internal wastegate with 18psi actuator but can easily have an external adapted to the rear housing as u will see in the pics
this turbo has not been run since being rebuilt about 8 months ago
this turbo would be good for any type of rb25det/26det/30det
will swap for something smaller and in good condition anything with a t3 flange and maybe a cash adjustment depending on the turbo your offering, so let me know what u have got
will sell for $900 ono
any questions pm me or call me on 0422258117
cheers
brad
Edited by RB20/30Det_VL
swap for r33 stock turbo in good condition, plust adjustment.
What did u have this turbo on? i see its a garret but it is not a truck turbo is it? with the split pulse design i have to ask.
tmc_2 sent pm
no its not a truck turbo, this was on my 25/30det and u find that most of the larger turbos with 0.82 or 1.06 rear housings will have split pulse housings
cheers adriano
as adriano said i have moved back home and it is of no use to me due to destroying my 25/30det months ago, now have my old rb20det and this turbo is to big
aquariuz6 - full boost (18psi) was seen at 3800rpm with supporting mods
and has never been used since rebuild, also has a 360 degree thrust bearing
brad,
sorry to hear your toolbox and turbo were stolen from work
already had the R33 gear packed up ready to post to you....took me quite a while...... like a jigsaw with padding
anyhow i'll keep an eye out on all the forums i'm on in case the w#nker tries to unload it....it's pretty oddball so i doubt there'd be 2 for sale
regards
paul
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 馃槢
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
