apparently it fouls your plugs pretty quickly?
dont quote me on that however.
why do you use octane booster? is your car tuned for a higher RON?
I agree mitchy, I can remember seeing a test done on TV and the only thing the octane boost did was boost the cash outer your wallet.
gun-r32, I would jsut stick to the good ol' BP 98... in a years time think of the $$$ you will have saved on the octane boost and you can buy me a pressy for the tip! :D
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2479088
even if it is tuned for higher octane, may aswell just get it tuned for 98ron or something more commonly available.
the money you save on octane booster will allow you to buy more mods to make up the slight loss in power from lower octane. :D
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2479192
the money you save on octane booster will allow you to buy more mods to make up the slight loss in power from lower octane. :)
Ahhhh.... wise words from a wise man. :D
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2479199
the car was only tuned on ultimate 98 + some octane booster to reduce pinging. I was advised that I should try to use some octane booster every fill, more as a safeguard than anything. Might try a few fills without and see if the knock level increases at all.
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2479394
i bought a bottle of wynns or sumthin octane booster the other day, havnt used it yet cos i hardly put more than 20 bux of fuel in at a time, most probably wont get to use it as aswell, lol, the person at the shop said every 6 months put a bottle in just to get the stuff through the system lol i just bought it cos i was bored :down:
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2481747
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
