Hey guys installing a second battery in my car have got a Battery isolator for the batteries but got no idea where to find the alternator wire is going to the main battery.
Need to find that disconnect it and connect it to the isolator then connect the to battery + to the 1 and 2 posts of the isolat...
So can someone please tell me where the alternator wire is.
Its got to run to the battery somehow doesnt it?
Edited by bygrave316
https://www.sau.com.au/forums/topic/133670-alternator-wire-got-no-idea/
Ok... I did some really heavy and deep searching on the net about this..... all i could find was a really small mention about an aqua (light green) wire.....
so i had a look at the fuses in the boot next to where the battery is and pulled plasic surround out looked to see what wire was running to the 10a fuse for alt s (guessing alternator) to find that it is an aqua (light green) wire but this wire is about as thick as the wires coming out of your computers power supply.....
so is this the wire that charges the battery? i was expecting to find a much thicker wire for this?
Can anyone shed some light on this as im still not 100% sure about this.
it'll be burried with some other cables in a plastic tube wrapped in elec. tape. this is what it looks like on my R32 gtr. notice the 'stray' wires, it is/was burried amongst these in a plastic tube.
hope those pics help :down:
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
