I'm trying all the combinations for you... There was a HR33 with that number (051375) which was a GTS/G with a RB20 (no turbo) (Jan 1995), and there was an ER33 with that number, which was a GTS25/s with the RB25DE (ie no turbo) (Jan 1996)
Hope that helps...
Ian
ok have re-checked the numbes again and this is what it says
Blue Japanesse plate
chassis # ECR33-051375
MODEL GGKBRTFR33VDA-U---
QM1 K
RB25DET 2498
FS5R30A RC41
the chassis number is the same as the one written on the firewall of the car with a line cut through it?
So on the road for around 37000?
Yeah something like that... but don't think i won it :) . Interestingly or dodgely whichever way u look at it, it was being auctioned as an '01 whereas it appears it was actually August 2000.
I'm downloading the software (Nissan FAST) now but it aint all that 'FAST!' it will take 5 days/nights on dialup...... arghhhh all in the love of the skyline!
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
