OK! heres a Question who the nissan fast can idendify the interior trim colour and type? can you tell me how you did it? is says C
~~ hc33 003262 ~~
I hate the comon poo coloured laurels but there is a black/grey interior i would kill for. FAST says it has a build date of 89 01 so it would be eligable for import just missing the 88 model cut yes? i think its 89 jan and older that makes it. sorry but im learnin haha
m guessing he mean BNR32 not HNR
heres the result
<<<<< P.S. how do i see the 'attached thumbnails' as I can't see anyting here.
Thanks for having a look guys, just went and double checked and go the other number if that helps.
HNR32-007303
with : KRNR32RGFSLMEB
the car is a gts4 not a gtr if that helps
thanks
Stephen
should just be a small thunbnail you can click on.
found the HNR number after i entered the model code then entering the 2nd part of the HNR code...bit strange...anyway here you go
thanks for doing that, only one prob for me at the moment is that I can't see any thumbnails. is there a setting in IE that stops me from seeing thumbnails
again , any help appreciated.
thanks
Stephen
I have a S3 GTR apparently could be a 98...go figure. Having alot of trouble getting parts for the gearbox as it is different to all other GTR's for some reason. The car has factory leather also...weird. I also have a 56K issue. Could someone help me Pls. =)
here are all the details I could find
E-BCNR33
Chassis BCNR33-043389
Model GGJPRWFR33ZZA-EQ-C (changed)
FS5R30A (Trans type?)
RC41 (paint?)
thanks
matt
That's not a valid chassis number as far as FAST is concerned.  Double check it.  Probably explains why Nissan can't identify the correct parts.
I double checked and it definately has BCNR33-043389 on the blue plate and fire wall. Maybe checking a few numbers out might give me an idea... ie 043387,043390, etc.
According to others my gearbox is the same as a R32 GTR ? not sure how that works.
Which part refers to the date of manufacture?
FAST says that GTR #043388 was manufactured in April 1998, while 043390 was an Autech GTR also manufactured in April '98. Only Nissan knows why your car VIN is invalid, but you might be able to get away with buying parts using the 043388 number since at least theoretically yours should use the same production parts.
Yours should have a late series pull clutch type GTR gearbox, but I suppose it's possible an R32 GTR gearbox was fitted as a replacement at some time.
The date of manufacture is determined from the complete VIN.
Ok, cool. Sounds like it could well be a 98...crazy, can't say I've ever heard of a Series 3.5. Makes sense tho with the weird stuff it has on it, like big sump oil cooler, leather and nismo dials.
What is an AUTECH ?
I checked as my clutch and box is out and the clutch is a pull type. I'm going to the gearbox specialist tomorrow to check if some parts i orderd for a 12/97 and newer fit.
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
