Can someone check this engine number for me. Thanks guys.
RB26 D20423A
For the record I got this number from the shop at which I ordered my rb26 so i am not sure it is the right number. If this is not the correct format for an engine number let me know. I dont really trust this shop but they were the only ones who claim to be able to get an r33 motor so I am checking everything i can to verify if it is a 33 thanks.
nah that wont work... it should be like HCR32 XXXXXX or ECR33 XXXXXX for e.g
also the "D20423A" part doesnt evan fit into fast... u can only put 6 characters in :ermm:
RB26
No problem, but maybe you need to change your ID >_<
Still looking for a GTR, this is one car that I have been looking at in japan...just wanted to check the build date before I pursue it any further...in the end I might have to my id. :)
Also can anyone do a breakdown of this code.
GGJPRQFR33ZDAGJ
Thanks again for the help guys.
Edited by 96_GTR
All it came up with is the info below. Obviosly need the vin for a compltete build date and so on.
Still looking for a GTR, this is one car that I have been looking at in japan...just wanted to check the build date before I pursue it any further...in the end I might have to my id. >_<
GGJPRQFR33ZDAGJ
Thanks for the quick reply again kjb_r33. Much appreciated. I guess I wasn't concise enough in my last post.
Is there a way to tell what the letters mean in the Model code GGJPRQFR33ZDAGJ that FAST has given.
all i can find on it.
Let's work through one... GGKBRTAR33VDAA---B
The first digit defines the body type... In this case G for 2 door Coupe... (It's B for 4 door Sedan)
The next 2 digits define the engine type and size (note: not the fact that it is NA or Turbo)... in this case GK for RB25DE(T)
The next digit (4) defines the drive type... In this case B for 2WD...
The next digit (5) is R across all R33's... I'm unsure of its significance... Some translation is required here...
The next digit (6) defines the model spec... (eg: GTS, GTS25, GTS4, GTS25T/M, GTS25/S, GTR, etc...) In this case it is T for GTS25T/M + GTS25/S (note: we still don't know if it is NA or turbo yet)
The next digit (7) defines the transmission... In this case A for 4 speed auto... (It's F for 5 speed manual)
The next 3 digits (8, 9 & 10) define the Model Series... In this case R33 for (duh) R33...
Now comes the tricky part...
The next digit (11) defines the induction system... In this case it's V for Forced Induction... (It's E for EGI / NA)... Some further translation is required here...
The next digit (12) can be either D or Z... I'm unsure of its significance... Some translation is required here...
The next digit (13) is A across all R33's... I'm unsure of its significance... Some translation is required here...
Shown below are all possible entries for the first 13 digits of the R33 Model Codes...
Note that different years have different designations for the digit (mainly to cater for the GTR's and GTS4's)...
R33 Model Codes (14-18)
Erghh... So many options...
The only one I have semi worked out is the last digit (18) which will be A if you have an Active LSD, B if you have ABS, and C if you have an Active LSD and ABS... There are heaps more options for digit 18 though...
It appears digit 14 is mainly focused on the wheel and tyre sizes...
It appears digit 15 is mainly focused on the electronic options (eg, ASCD (cruise), GT spoiler, etc)
I am unsure what digit 16 is mainly focused on...
It appears digit 17 is mainly focused on the AV options (eg, CD, MD, Stacker, etc...)
Edited by kjb_r33
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
