Just took me 1 or 2 goes to enter the info in the correct fields and all good from there.
Am hoping that funkymonkey or others are able to work out how to query the databases on stuff. eg I want to know the number of vehicles made with my paint code.
ps Your colour 326 shows as white btw.
thanks guys.  Very strange as that is how I entered it and it did not work.  Just tried again and it has now got the information.  I wonder is it has to index a database or something before working?
maybe you tried bnr32 .. not brn32 as you first post read
Well Sameer ( Horus ) is selling a great low klms GTS-t 89 that is eligble for import in September for $10,000 Landed and Complied.
Here is the chasis number , can people get some more info on the car if possible with the '""fast""" software from nissan ?
thanks !
HCR32-026287
  • 1 month later...
Guest Variable
Hi guys,
I've got FAST working thanks to Strutto's great instructions, found my car (whew!) and noticed many of the part numbers in the exploded drawings are only 5 digits. Any parts I've bought from Nissan are usually in a 5-5 format. Does anybody know how to get the complete part numbers?
Cheers
Dirk
  • 4 weeks later...
  • 4 weeks later...
Sorry to ressurect this but it IS possible to get full part numbers using the FAST software. Once you know the part code (the first 5 digits of the full PN), it's reasonably simple, although I suspect there may be a little more to it than what I've found so far. If you don't know the part code, you need to navigate to the relevant parts illustration to find it - I'm not going into it here as others have decribed it earlier (and it's worth trying for yourself anyway to get familiar with the system).
Anyway using the timing belt example (below), go to the initial FAST window and make sure the model series at least or VIN are entered. In this case use R32 or (as I did) your VIN. Now go to the 'Part Code....Qty....Part No' Line and click on 'New', then go to the 'Part No' field and enter the first 5 digits of the PN (ie 13028). The system should automatically enter a dash after the 8.
Now click on 'New' again and a window should pop up with some info about the part (but not the PN....yet). Click once in the blank 'Ord.Qty' box to 'order' one belt (or click as many times as you want for the number of belts you need) - that number should appear in the box. Highlight and backspace to delete quantity. Either hit F5 or go to the 'Tool' menu and select 'P/No Search'.......voila, the PN appears along with a bunch of other stuff in the original 'FAST' window. There's also 2 new buttons in that info list - one gives basic model info, the other gives superceded parts info, if applicable.
Well, it worked for me....
strutto looking at the part numbers on some parts i allready have it does not show full parts listing IE
rb20det
say a timing belt on fast is is listed as 13028
but the full part # is 1302820p25
does anybody know how or where the full parts listing is for each part ?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
