hey, im new around here but was wondering if someone could decode this for me:
Chassis - HCR32-011224
Model - RCR32GASLM IC
COL? - KG1 G
I can't manage to get the FASt software! but from what i read above that this should be an automatic but its a manual. wondering if anything else has changed! (just looking at buying the car)
Thanks in advance
Anthony
South:
The vehicle deatils are as follows:
Build Date: 07/1989
Colour Code: KG1
Interior: G
Spec: M-Spec
Trans: Auto
Thanks very much for the info :D
Im taking that the KG1 is the silver colour? they must have done a switch on the transmision which makes me worry about the motor and the k's!
Anthony
I do not have a C:/WINDOWS/directory, I followed the steps to what i could understand it. I put the NSFASTKY.INI file in C:/ .
Is this the same thing?
PS: I',m using XP
not c:windowsdirectory
its supposed to read put it in c:windows
(windows directory) he added a by mistake after windows (typo)
Got that sorted last week :D
i think it has EVERY nissan ever made on them, you just need the correct cd, each cd does different cars .. i'll try find out which cd has the datsun 1600 510 series for you ..
It covers from 1979 and onwards.
yes thats exactly what it means......which might be a problem for compliance or 15yo import if its not in the country yet
Then something is going on. coz i am importing this under the 15 year rule becoz it's suppose to be a 1990 may GTR.
it has already got import approval could that date be wrong?
nOOSE
I was hoping that someone can help me out also (have embarrassing dial up in the country which is very slow)
ECR33-051375
GGKBRTR33VDA-U---
I know what the bulk of the model numbers are but not sure on the last few digits are -U---
my rego papers say it is a 1995 my Green plate say 11/1994 and I just need to know if the car is series 1 or series 1.5
greatly appricaited
ECR33-051375
GGKBRTR33VDA-U---
greatly appricaited
It was made in 93/08 - so it's actually a 1993 car!
Edit: Cancel that - I think I screwed up entering the code!
Ian
ohh and you got me all excited then thinking someone mght have an answer for me ;)
Sorry about that.
When I type yhe number in that you gave (ECR33-051375) it comes back with "model series can not be found for this vin no"
The one that I actuall commented on was ECR33-005137 - I'd left the five of the end, and had an extra zero at the front.
Are sure your number is correct and that you don't have a digit wrong????
Ian
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
    • I couldn't agree more. As an owner of a built high HP skyline, I'd be a hypocrite to not buy a Hummer for the reasons you listed though haha.
    • Hahaha oh shit! Again!
