OK! heres a Question who the nissan fast can idendify the interior trim colour and type? can you tell me how you did it? is says C
~~ hc33 003262 ~~
I hate the comon poo coloured laurels but there is a black/grey interior i would kill for. FAST says it has a build date of 89 01 so it would be eligable for import just missing the 88 model cut yes? i think its 89 jan and older that makes it. sorry but im learnin haha
m guessing he mean BNR32 not HNR
heres the result
<<<<< P.S. how do i see the 'attached thumbnails' as I can't see anyting here.
Thanks for having a look guys, just went and double checked and go the other number if that helps.
HNR32-007303
with : KRNR32RGFSLMEB
the car is a gts4 not a gtr if that helps
thanks
Stephen
should just be a small thunbnail you can click on.
found the HNR number after i entered the model code then entering the 2nd part of the HNR code...bit strange...anyway here you go
thanks for doing that, only one prob for me at the moment is that I can't see any thumbnails. is there a setting in IE that stops me from seeing thumbnails
again , any help appreciated.
thanks
Stephen
I have a S3 GTR apparently could be a 98...go figure. Having alot of trouble getting parts for the gearbox as it is different to all other GTR's for some reason. The car has factory leather also...weird. I also have a 56K issue. Could someone help me Pls. =)
here are all the details I could find
E-BCNR33
Chassis BCNR33-043389
Model GGJPRWFR33ZZA-EQ-C (changed)
FS5R30A (Trans type?)
RC41 (paint?)
thanks
matt
That's not a valid chassis number as far as FAST is concerned.  Double check it.  Probably explains why Nissan can't identify the correct parts.
I double checked and it definately has BCNR33-043389 on the blue plate and fire wall. Maybe checking a few numbers out might give me an idea... ie 043387,043390, etc.
According to others my gearbox is the same as a R32 GTR ? not sure how that works.
Which part refers to the date of manufacture?
FAST says that GTR #043388 was manufactured in April 1998, while 043390 was an Autech GTR also manufactured in April '98. Only Nissan knows why your car VIN is invalid, but you might be able to get away with buying parts using the 043388 number since at least theoretically yours should use the same production parts.
Yours should have a late series pull clutch type GTR gearbox, but I suppose it's possible an R32 GTR gearbox was fitted as a replacement at some time.
The date of manufacture is determined from the complete VIN.
Ok, cool. Sounds like it could well be a 98...crazy, can't say I've ever heard of a Series 3.5. Makes sense tho with the weird stuff it has on it, like big sump oil cooler, leather and nismo dials.
What is an AUTECH ?
I checked as my clutch and box is out and the clutch is a pull type. I'm going to the gearbox specialist tomorrow to check if some parts i orderd for a 12/97 and newer fit.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
