Ok my VIN is 18 digits but FAST will only let me enter 17, what gives?
Spook33: That's an engine number I think.
I tried both my VIN and Engine number (one 18 one 17 digits) with no success.
I also tried to one that BBGTR did above and got no results either.
I've copied all 5 CD's to the right directories and poined the setup program at them as per the instructions. Those CD's are listed in the bottom right hand corner of the program but still nothing works!
What gives =\
Edited by ActionDan
What gives =\
the digits and letters in front of the "ECR33XXXXXX" is what they add on when they're imported....FAST is a program from NISSAN , so it will only recognise the japanse VIN, which in your case will be ECR33 XXXXXX
:laugh:
T326 - Crystal White
732 - Black Pearl Metallic
AH3 - Red Pearl Metallic
AN0- Super Clear Red
AR1- Super Clear Red II
AR2 - Active Red
BL0 - Greyish Blue Pearl
BN6 - Deep Marine Blue
BP9 - Dark Blue Pearl
EV1 Lightning Yellow
EY0 - Silica Breeze
GV1 - Black Pearl
JW0 - Millenium Jade
KG1 - Jet Silver Metallic
KH2 - Gunmetal Grey Metallic
KH3 - Black
KL0 - Spark Silver Metallic
KN6 - Dark Grey
KP4- Sonic Silver
KR4-Sonic Silver
KV2-Athlete Silver
LP2- Midnight Purple
LV4 - Midnight Purple II
LX0 - Midnight Purple III
QM1 - White
QT1 - White Pearl
QX1 - White Pearl
TH1 - Dark Blue Pearl
TV2 - Bayside Blue
WV2 - Sparkling Silver
as for the model code in the top right hand corner, you'll need to go back to about page 1 of this thread, and decode it using the post that has most of the translations....it can be a bit time consuming :laugh:
Well good to know that my car was always Super Clear red II =D
I'll check the model codes..
Just checked and got some insights, wtf is an active LSD, as apparently I have the letter that denotes this option coupled with ABS which I already knew I had... I knew it had 'an' LSD but wtf is Active all about or just some naming shizzle?
Edited by ActionDan
  • 3 weeks later...
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
