ER3407890
Here you go (with options page).
Model: R34
Series: 25GTT
Built: June 1998
Colour: Sonic Silver
Body: 2 door coupe
Transmission: 5 speed manual
Options:
15 = Rear wiper + UV cut privacy glass + Xenon Headlamps
16 = Glovebox light + remote entry + trunk lid
If anyone wants to check the translations for the options, please do so.
BNR32 314356
KBNR32RXFS7AA
Date: 9411
Ext: AH3
Int: G
2K
RB26DETT
HICAS 4WD
GTR
MT.F5
I *think* that means non v-spec
I cant get that options thing up like SMR33 either (different version maybe? fast 3.5, 2001/10 cd;s)
Edited by TonyL
PS13-006847
PS13HACM29
Here you go. Can't tell about the Nismo bar.
BNR34-404031
This number does not appear in my version of FAST, sorry.
BNR32314356
I do not think this is a v-spec. The codes point to being a GTR only. Besides the build date is in 1994, v-spec II was being made then, not v-spec.
The model number is KBNR32RXFS7AA, which I'll describe below (as best I can):
K = hard top (ie coupe)
B = RB26DETT
N = 4WD
R32 = R32
R = 2 door
X = GTR
F = 5 speed
S = intercooler turbo
7 = 16 inch tyre (if it were a v-spec II it would have '8' here, which would indicate the 17 inch BBS wheels which came on a v-spec II)
AA = other options which I'm not sure of as these are listed in kanji.
Hope this helps you out anyway.
The options screen I posted previously is for a 34 (similar screen for 33). The screens containing options for a 32 are much more long winded (ie 27 pages worth) and its pretty much all in japanese (including a lot in kanji).
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
