Can someone check this car for me? If you can tell me where to get the program myself that'll be better than bugging people to decode for me.
http://www.carsales.com.au/pls/carsales/...4&make_id=5
VIN: 6u9000bnr34
Cheers
http://www.carsales.com.au/pls/carsales/&a...4&make_id=5
VIN: 6u9000bnr34
Cheers
you need the last 6 digits of the VIN for that.
i got this programme and used iton a r33 im i nthe process of buying... apparently the 2 door manual is actually a 4dr auto??? the caryard guarantees it is all genuine though? is it possible that the vin was swapped back in japan and once here the compliancers had no idea? or is it more likely something dodgy has happened while in aus.
thanks.
  • 5 weeks later...
thanks.
It could be a simple case of transposing a number when you ran the VIN through FAST. Post it up or try it again for yourself just to double check.
ER34021493
Model: R34
Series: 25GT
Built: February 1999
Colour: Athlete Silver
Body: 4 door sedan
Transmission: 4 speed auto
I ran my vin through Nissan FAST to look for the part number for the a/c compressor and it came up with two different a/c compressors with different part numbers.
Does this mean that they are both compatible with my car?
Can anyone help me out?
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
