Hi everyone. Im saved up a bit of cash and want to mak the 33 go that little bit harder. I have recently read here that ppl dont advise running more than about 12 psi on the stock turbo (i currently have the boost set to 10) If i wanted to raise boost levels to say 15-16psi is it better just to hiflow the stock turbo as opposed to buying a new one which seems like the much more expensve alternative. How do ppl rate hiflows?
https://www.sau.com.au/forums/topic/133745-to-hiflow-or-not-to-hiflow/
Have you installed an ecu?
With a highflow, you will need an aftermarket ecu, then fuel pump, then injectors to get the full potential.
Buy an ecu first, this unlocks sooooo much hidden potential within the std motor/turbo.
I have a hi-flo and new ecu...basically get urself something like a PFC first. also look at the zorst, AFM etc before u bother i guess. few post aboutt what to do first.
yeah ok cool. i already got exhaust and cooler and was gonna get the power fc now with the turbo. How r u finding the hiflow? is it noticibly lagier?
i would definately recommend the hiflow option. good power increase over stock. i got a vg30 single turbo exhaust housing adapted to mine for abit more top end :down: result being 346hp(258kw) at wheels on 15psi. u make up your own mind !!
so on stock r33 ecu you have 346rwhp ?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
