Hi everyone. Im saved up a bit of cash and want to mak the 33 go that little bit harder. I have recently read here that ppl dont advise running more than about 12 psi on the stock turbo (i currently have the boost set to 10) If i wanted to raise boost levels to say 15-16psi is it better just to hiflow the stock turbo as opposed to buying a new one which seems like the much more expensve alternative. How do ppl rate hiflows?
https://www.sau.com.au/forums/topic/133745-to-hiflow-or-not-to-hiflow/
Have you installed an ecu?
With a highflow, you will need an aftermarket ecu, then fuel pump, then injectors to get the full potential.
Buy an ecu first, this unlocks sooooo much hidden potential within the std motor/turbo.
I have a hi-flo and new ecu...basically get urself something like a PFC first. also look at the zorst, AFM etc before u bother i guess. few post aboutt what to do first.
yeah ok cool. i already got exhaust and cooler and was gonna get the power fc now with the turbo. How r u finding the hiflow? is it noticibly lagier?
i would definately recommend the hiflow option. good power increase over stock. i got a vg30 single turbo exhaust housing adapted to mine for abit more top end :down: result being 346hp(258kw) at wheels on 15psi. u make up your own mind !!
so on stock r33 ecu you have 346rwhp ?
