Hi everyone. Im saved up a bit of cash and want to mak the 33 go that little bit harder. I have recently read here that ppl dont advise running more than about 12 psi on the stock turbo (i currently have the boost set to 10) If i wanted to raise boost levels to say 15-16psi is it better just to hiflow the stock turbo as opposed to buying a new one which seems like the much more expensve alternative. How do ppl rate hiflows?
https://www.sau.com.au/forums/topic/133745-to-hiflow-or-not-to-hiflow/
Have you installed an ecu?
With a highflow, you will need an aftermarket ecu, then fuel pump, then injectors to get the full potential.
Buy an ecu first, this unlocks sooooo much hidden potential within the std motor/turbo.
I have a hi-flo and new ecu...basically get urself something like a PFC first. also look at the zorst, AFM etc before u bother i guess. few post aboutt what to do first.
yeah ok cool. i already got exhaust and cooler and was gonna get the power fc now with the turbo. How r u finding the hiflow? is it noticibly lagier?
i would definately recommend the hiflow option. good power increase over stock. i got a vg30 single turbo exhaust housing adapted to mine for abit more top end :down: result being 346hp(258kw) at wheels on 15psi. u make up your own mind !!
so on stock r33 ecu you have 346rwhp ?
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
