  • Replies 100
Sinesweep/hip,
The "no spectators" ruling is due to insurance issues. AIR's insurance policy is very clear cut, private track hire day - NO spectators :D I think you'll find drivers, "pit crew", media & AIR staff are covered seperate to general public.
With ~50 cars entered (& therefore 100 pit crew permited) surely there'll be a few spare "pit crew" spots that people can take advantage of!?
  • 3 weeks later...
I dont know if i will be able to enter the drag day at this stage as im having ignition problems. Seems i will have to get some Autronic iginition coils ($1500) so i dont know when that will be happening. Also got to get the pick up of the tank modded.
Mel has refered to her Jap transplant SR20 NEO VVL (200hp) powered Pulsar as the Poosar :) Flat 15's in an atmo 4cyl is nothing to sneeze at!
  • 4 weeks later...
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
