As the topic says, I have two quick PFC questions.
The car has to go into the panelbeaters for a couple of weeks. :D
1 - Will the PFC loose its programmed settings if the battery is disconnected for an extended period? (2 weeks maybe)
2 - What can I do with the PFC that will stop any idiot having fun while I leave the car there.
For instance, can I program a temporery 3000rpm rev limit without stuffing up my usual PFC program?
https://www.sau.com.au/forums/topic/133756-2-quick-pfc-questions/
1) Disconnecting battery will not make it loose setting
2) You can setup Rev limiter via hand-controller, then disconnect the Hand controller so they can;t change it unless they have a hand controller handy, further more u can set the rev limit & lock the ECU if you have the software.
Great :)
Is there any guides around for that in English?
My PFC manual is in Japanese. :D
heres a good read:
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
it might be there not sure , i remember seeing it somewhere around..
here is the manual though in english
http://paulr33.skylinesaustralia.com/manua...r_FC_manual.pdf
Edited by Nav2k
