Drive was nice out to hanging rock, everyone was spread out a bit more.
Pity there was very little there and a $8 charge to get out of the picnic area once your in.
Anyways good to see a legend remembered with a big turn out.
  • Replies 91
Hey ppls.
Yeah, I had a good cruise up until people DISREPECTED Peter Brock by ripping skids on a public road right neat the heart of Holden, the Engine Plant.
Peter Brock was passionate about road safety and I was dissappointed to see that even 30 minutes into the cruise people were acting like d1ckheads. It only takes the BIG moment that people had on the Westgate bridge to realise that doing the sort of crap you were doing on public roads is plain stupid.
I was hoping that in respect of Peter Brock that this wouldn't happen but I was sadly mistaken.
I know it was any import drivers, and I'm not going to name name about who it was, but it did make me sad and angry on the day.
Anyway well done to those who kept their sh1t together and acted properly on public roads.
BASS OUT (So much sausage I can never look at a BBQ the same way again)
Get a life dickhead.
I love flutter, I was fluttering every import and VL I could get next to during the majority of that cruise.
IF YOU GOT IT FLAUNT IT
Need I say anymore? :)
thank
you
Same goes for you rim. :P
Anyone spot the cop in the blue ford parked sideways near the normanby rd intersect on leaving?
Too bad the hot Porsche owner didnt as he gunned it pass all the imports/VLs.
Last seen the cop was hot on his heels :P
We saw the cop still parked there when us SAU guys left...thought he was just there to make sure no one was being a tard when leaving (which is fair enough) but he actually had the speed gun out on us....
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
