  • Replies 91
I may have to dust off the monaro for this one as well... Hope to see you all there
R31 skyline club will be there, bringing possibly 10 or so cars. as has been said, this is for all the right reasons. and good chance for all the clubs to represent.
wat a perfect day to cruise
some nice cars out
sooo many "I pitty you Fools" and RLXBRO's out and about today
man! the Z28! Crikey
Z-Tune and NUR at Dutton :(
nice meeting you guys
poor skyline who got rear ended, lucky Bass escaped unscaved
soo many cars...if I never hear VL turb dose flutter again it'll be too soon... they were goin off every 2 seconds, weather we we're parked at GMH or cruising down the highway...
was a huge turnout, I'm sure brocky would have felt pretty special seeing all the support for him.
only downside was the typical "who got the bigger dick" burnouts and the average looking tiny "brocky" stickers.
hope all went well for the second half of the cruise, as I decided to head to sandown for the arvo.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
