post-30251-1157944974.jpgpost-30251-1157944418.jpgpost-30251-1157944523.jpgpost-30251-1157945223.jpgpost-30251-1157945249.jpgpost-30251-1157945306.jpgpost-30251-1157945344.jpg[attachmen
=55302:attachment]post-30251-1157945145.jpgpost-30251-1157945059.jpgHi everyone my skyline is back up for sale. Last buyer did not get loan. It is a 1993 r33,gtst.Rego till may 2007. It is in very good condition. It does have stone chips on the front bar. Otherwise paint is perfect. Resprayed 2 years ago. Engine has Forged pistons. Seal pro rings. New std Bearings and Crank con rods. Arp Head stud kit. 1.8mm Metal head gasket. Ported and polished head. Isky 90 PSI Valve springs. Reground cam shafts. Gates racing belt. G Reddy Adjustable cam gears. XTR 30/40 bb turbo with XTR turbo nappy. Ceramic coated exhaust manifold. Port matched 38mm Tial Wastegate. BOV. 660cc Sard injectors. Sard fuel pressure regulator. Xtr Motorsport HP fuel pump. Iridium spark plugs. Brand new z32 Air flow meter. Spitfire ignition coils. Other accesories are HKS Pod air filter. HKS Super dragger exhaust. High flow cat.Heat wrapped dump pipe. E Boost 2 controler. Apexi power fc and hand controler. R33 GTR Intercooler with custom piping. Oil catch tank. Lightened fly wheel and ceramic clutch. Kaaz 2 way diff. Car also has mp3 player. 18'' mags. Alarm. Whiteline swaybars. Whiteline suspention kit. King springs. Interior is immaculate. Car is very fast and very reliable. Any test welcome.$18500. Please contact me on 0403603203 or (02) 99698555 for more info about car.
Edited by philstar
https://www.sau.com.au/forums/topic/133818-r33-gtst-270rw-kw/
  • 3 weeks later...
DMAn ! i only have 15.5k to spent on da car !! :) i like ur car mate ! but i jus dnt have enough to pay. doubt u will drop to 15k aniwaiz . if yes pm me =)
G_luk with da sale though =)
Cheers. try to get some more cash together and then we may do business.
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
