Jack at the rear use the diff,
at the front the crossmember as it is one of the stronger points, otherwise use two trolley jacks and under the lower control arms on the front and these are cast and rather strong...
but do NOT put the jack anywhere near the steering rack, sway bar, sump or gear box as the result may cost more than an arm and a leg...
To be quite honest I would use the jack and then place axle stands underneath for more even distribution, remember use the right tool for the right job.
  • Replies 75
Posted Images
a tyre shop jacked my r33 up on the front sills. It popped both my front guards out and flattened the ride with the jacking point marks in it. I didnt notice it until a few days later so they wouldnt fix it. I have since noticed alot of skylines with the same, bottom of the front guard popped out slightly.
  • 3 months later...
If you are jacking your car up on a completely flat surface (garage concrete floor) your car isn't going to move anywhere if you have wood/bricks infront & behind the other 3 wheels.
I just use the factory/standard jack points (which of course are damaged).
I also have to drive the front wheels up onto some 4x2 because of my sideskirts being too low.
I use the factory jacking point in the sills to jack up the car, a piece of 6"x4"x2" hardwood with a slot cut in the top (3/4" deep 1/2" wide across the top face) goes between the jacking point and the trolley jack. Zero damage as the load is taken the same as the factory scissor jack.
is this the crossmember?? and this diagram is of the r32 gtst, i couldnt find the r33 one.
Yes thats the crossmember....it's in the same place on the R33.
If you want to raise the front of the car you need the jack in the middle of the crossmember at about the centre line of the car. A little trial and error is involved. the car doesn't weigh exactly the same either side of the centreline so it will come up one side lower than the other. Lower the jack and move it an inch or so towards the low side. Repeat the moves until it comes up nice and even.
  • 3 weeks later...
Heres some pics which may help you on where to jack and place stands under the car.
I always jack up on one tow point on the front, then place a stand under the other to get enough height for the jack to get under the cross member. Then simply jack up on crossmember and place stands underneath cross member.
Hope it helps
Frank!
  • 2 months later...
well only if you don't give a **** about the structural integrity of the car.. if I was buying a car its one of the first places i look, to check to see there is no obvious chasis bends. If all the sills etc were bent to shit I sure as hell wouldn't be buying it.
and any workshop that i know was doing that I wouldn't be taking my car to anymore either.
Damn straight!
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
