Hello to all SAU member,
Im a new proud owner of a 94 r33 gts series 1 (to bad it wasnt a gtst because iam on my P's) and also it is my first car. I've moved states (NSW to VIC) and i thought the SAU is a great opportunity to make new friends
Little about the car:-
Bought for: $11000
Transmission: Auto
Colour: Dark Blue
K's done:100200
When i first bought the car, it was stock as!
Mod's I've added to my car in the past month:
HKS filter
Trust Power Extreme II exhaust
Sony xplod cd player
Clarion 6" split speakers
17 inch Vault rims
(yet to get coloured and fitted) series 2 wing
Mod's for the near future:
Bodykit
So thats about it! If you guys have ideas for my car just post it or pm me.
Looking forward to hear from you guys.
Thanks
P.S.
I've added a few pics of the car when i first got it.
Will attach a few pics of the car of what it looks now, in a couple weeks.
Edited by SKYLN3
https://www.sau.com.au/forums/topic/133843-newbie/
Hello to all SAS member,
welcome.
don't mind dezz...
enjoy your stay.
https://www.sau.com.au/forums/topic/133843-newbie/#findComment-2481524
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
