hey guys i got my old wheels for sale due to having a wide body, there 9inch alround withe 245 alround,
front tyres would have bout 40% tread and rears bout 70% i want $700 for them
they will be off the car by the end of the week when i get my new wheels.
and will take better photos when off
u can contact me on
0404961159
2 wheels have have slight gutter rash tyred to take fotos of them
post-16324-1158749603.jpgpost-16324-1158749312.jpgpost-16324-1158749229.jpgpost-16324-1158749755.jpgpost-16324-1158749964.jpgpost-9094-1127729082.jpgpost-16324-1158750845.jpgpost-16324-1158750948.jpg[attachmen
Edited by ali-turko
https://www.sau.com.au/forums/topic/133848-sparco-wheels-cheap/
mate i dont no the exact off set but i would say the would be around the +20, but had the rears on my gfz gtst at one stage but not sure bout the fronts the might fit i really dont no, but ur welcome to come and tryem on when there off
They should fit GTS-t if you put them on one before. front and back offset is the same on GTS-t's i have changed my wheels around before.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
