i just got a set of second hand hks hyer d coilover for the rear of my r32 gtst i just slaped them in now n took em for a spin. they r realy soft. the valve down the bottom of the shocker has that got anythin to do with the damper. and on the top plate is like a little rod stickin out.
thanks for your help
https://www.sau.com.au/forums/topic/133863-help-with-hyper-d-coilovers/
adjustment is usually on the top, adjust with screwdriver/allen key or turn by hand, or a knob at the bottom, just turn it.
im guessin the "valve" your talkin about at the bottom is a knob and this should be your damper adjuster
na the one on the bottow is the same a the valve to pump up your tires. on top in the middle of the top plate has like a allen key sticken out the top
