on most cars there is still a good 10-15L in the tank when the light comes on
its always interesting to fill up when the light is on - count the litres and see how much u had left in the tank - makes it pretty easy to work out
yeh i get told some ppl can do another 100km on their tank when light comes on, so me thinking it was a good idea to drive around a lil more b4 filling up, only went like 30-40 km, was thinkin 50 would be the limit... went around the corner, and it started chugging like it was about to stop :rant:, lucky this was at 1am at night, and in kalgoorlie (country town) everything is pretty close, i just babied her at like 20kmh to the petrol station... $110 later she was full again :D
The fuel gauge on the R34 must be very cautious! When my fuel light first comes on I still have over 20L in the tank.
So on 45L I do 450km, theoretically if I drove it till she was dry (20L = 210km) I'd get about 660km out of a tank?
Holy jeebus.
Edited by Lithius
Holy jeebus.
660km? thats awesome i only do nearly 400km on a full thank...
in the pulsar I could drive for ages on the fuel light, it was really conservative.
in my R33, even once the fuel light comes on it goes back off occasionally as the fuel moves around (going up hills or down hills or whatever).
however, during this on/off phase i fuel-surged going around a corner so now I fill up as soon as the low fuel light comes on. not worth the risk on a turbo motor, unless you drive like a grandma with the fuel light on.
i did manage 657K's out of my last tank and felt it was time to fill up but only refilled with 59L. I'm on target for at least 640K's on this current tank of fuel.
I was always told it is bad to run right to the bottom of the tank, cos you pick up all the stuff that normally sits in the bottom....I had issues with my commodore a while back with fuel pumps shittng themselves because of excess buildup of sludge and crap in the bottom of the tank....
Just curious, 10KM from a servo that's all...
What's the furtherest you have had the balls to push it when the empty light is on?
I once had a 1.3L 16V manual Charade two door that I did this very test on- One time, I drove for 180km from the needle touching the 'E' mark to when the car started to sputter and I pulled into a servo. I still can't believe I didn't have to push it :cool: Very economical little cars.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
