This is a message I typed up on Overclockers. Thought some people here might be interested too :)
Well, I managed to scrape some money together and pick up my car a day early. It ran rather late because the plenum is far from a perfect fit, and the guys at Hills had to do a lot of fiddling around getting it just right. When I got there they were playing around with the intercooler piping and the idling. But it's all back in one piece now.
Didn't have time to do a dyno run, but I'll try to get them to squeeze me in when I take it back tomorrow for 2 new front tyres and a wheel alignment. Oh, warning kids: Don't be stupid like me and forget to do a wheel alignment after you lower the car. Less than 10000km later I'm down to the metal belts on the inside of the front right.
*sigh* It's not the sort of thing you notice if you can't see the inside of the tyre easily at a glance. I check the tyres fairly regularly but I never really got a good look at the inside edges. A hard lesson well learned.
Thanks very much to the guys at Hills Motorsport, I don't think you'll ever meet a more bunch of dedicated mechanics that REALLY know what they're doing. This plenum was such an unknown and problematic factor that I think most other workshops would have thrown it out and told me to never come back :D
Oh, and how's the power now? Well, accelerating in a perfectly straight line, hit about 5500rpm in 2nd gear and the rear stepped out. I got scared :eek: Edit: hmm where's the eek icon?
Here's some pics. Yes I know the rocker covers look shite, thanks to the previous owner. I'll try cleaning them up on the weekend. The rest of the pics can be found here.
Looks Sweet,
Only one problem that I can see, the pipe that used to go to the tappet cover breathers to the turbo inlets has been removed and blocked at the turbo enterance thats fine but ensure that the bung blocking inside the flex rubber tube is NOT plastic as my car had this, well some months after fitting it melted and the turbo ate it dinging up the impeller. took me ages to get the melted & screaded plastic bung out of the i/c.
Regards Damqik
Looks good Jim - I thought you got a Hills plenum, but then I re read the post . he he. I was thinking...that doesn't look like mine.....Nice Aluminum welding there - Hills are tops at that !!
Cheers.
Nah I just got them to do the work and they were absolute magicians with it. When I bought my home made one 2nd hand I found out a couple of days later that Hills made their own :( Actually from one of your posts I think :(
Oh well, it'll give me something to upgrade in the future. Mine was intended as a cheap upgrade and I already went way over budget with the new intercooler. I don't regret doing that at all though.
Hard to say. The throttle is a lot more responsive down low and because of this it's hard to tell if the power is any less. But I'd say it's not very noticable either way and I'd rather have the better throttle response.
Sik32, there's more all through the entire rev range. So there is a lot more up top, but don't forget I also had a new intercooler put in to replace my old restrictive one. It was a combination of the 2 that gave me a hell of a lot more power.
Also, the more I think about it the more I think there's gotta be more power down low. The bog-down effect I had previously was partially because of throttle lag, but now I'm sure mostly it was because it had less power. You could feel the engine sort of almost stall before, and I'm sure that has to be due to less power rather than a delay in the throttle response.
If you have a front-mount intercooler and have the spare funds, I can't see any reason not to get a forward-facing plenum. It will definitely improve your throttle response, and alomst certainly add 10-20kw to your power.
I still haven't dyno'd it, the guys were too busy on Saturday :) I'll get it done when I get the new fuel pump put in and the S-AFC re-tuned.
Oh, here's a couple more pics that I took today after I cleaned up the cam covers.
Edit: Note the new position of the crankcase breather with the zip tie around it. It fell off! I looked under the bonnet last night and thought I had lost it forever, then I noticed it wedged down the side between the guard and heat shield or something. God knows how long it was there, I went for a very long drive on the weekend!
  • 1 month later...
GTS-t VSPEC, a couple of qns as i'm looking at doing the same on my R33 (Greddy intake plenum, FMIC with custom piping).
1. are you using the original throttle body, or an aftermarket one?
2. where have you plumbed your BOV? I plan to use the existing plumb-back factory valve
3. With the Greddy plenum can you use the existing fuel rail and injectors?
4. does the washer bottle need to be relocated?
Cheers in advance.
PS JimX, any dyno comparison yet?
Ronin,
I am using a custom 90mm throttle body, but it is possible to use the original one with an adapter plate. I'd recommend going the Infinity throttle body, as it is designed to fit the plenum:D
I have an after market BOV mounted prior to the throttle body.
I'm still using the existing rail and injectors, but now there is heaps of room for a top feed:
I have relocated my washer bottle, due to my intercooler piping.
Ronin, no. There's currently a BIG delay on even mild mods for my car now, probably won't get anything done until after winter. I've gotta upgrade my computer a bit for tax purposes, and then I've got my insurance policy renewal coming up in July. I'm scraping every penny that I can together.
After that the fuel pump will go in (possibly with a regulator as well) and the S-AFC will be tuned and the dyno results posted. I'll do a new post about it when it's done.
Gee, I hope this 044 fuel pump works! Or that I get it installed before the warranty expires :(
Oh, and thanks MrMayhem :(
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
