The whole upgrade I did was all about removing restrictions and increasing throttle response and therefore power and economy. I was getting huge amounts of pressure drop before, at 1 bar I think it was in the order of around 5psi. My economy has also improved after the mods, I was getting around 15-16L/100km before, and now it's down to 13-14.
The other reason why the front-facing plenum also helps power and economy (aside from the less pressure drop) is the intake doesn't go all the way back over the top of the hot engine, thus heating it up less. I guess to achieve the same effect on a stock intake you could just thermal-wrap the piping which goes back over the engine.
Because I also upgraded my cooler at the same time it's hard to say how much power I gained from each mod, but I'm very happy with the overall package and would never go back to the over-the-top plenum. One day I might sell this one and get the sexay Hills Motorsports plenum, but not for a few years yet.
It's around $800. $900 "fitted" would only be if you want to do a straight swapover from the existing plenum (it's around 1 hour's labour just for this part). But if you don't already have a front-facing plenum, you will be up for a few more hours work than this, to cut the chassis rail and run new intercooler piping to suit. You will also need to buy the extra intercooler piping (probably at least 1 bend, if you can re-use your old stuff).
I would set aside around $1100-$1200 for this upgrade if you already have the front-mount. You will also need a new throttle cable ($80 or so) because the original one is too short. Also with the Hills plenum they like to run the piping through where the windscreen washer bottle is, so you'd have to replace that with a smaller one if you still want to wash your windshield (+$100 or so for an alloy one). So probably closer to $1300-1400.
Add another $1000-1500 or so for a decent intercooler if you don't already have one, and another $450 or so for the piping.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
    • @Kinkstaah I've got my list.. but most of them is to do if I ever win the lotto
