I'm inserting this post around motoring forums to alert interested road users, particularly those in the NT.
Whilst I personally support the introduction of a rural default speed restriction for NT, it must be made 'quite clear' to MP's, that the adopted rural default NOT be applied on roads to which a speed derestriction sign is posted.
This means NT can then have BOTH a 'rural default speed restriction' AND 'speed derestriction allowance' as it applies right now, but only to a specific length of road, that is, where it is posted.
The speed derestriction sign (//) is an international road traffic sign, it's meaning in the UN Convention on Road Traffic, Road Signs and Signals "END OF ALL LOCAL PROHIBITIONS IMPOSED ON MOVING VEHICLES", hardly 'default speed limit', or 'speed limit 90, 100, 110km/h'.
SHOULD NT residents wish to retain the speed derestriction allowance, I SERIOUSLY advise you to CONTACT your local MP, see links below:
Let them know if you support a rural default or not, BUT ALSO - let them know to KEEP the speed derestriction sign, should a rural default arrive, so it can then be used on NT''s safest lengths of road.
MAKE THE EFFORT, or lose forever your right to drive 'safely' - unhindered, at speeds above 100km/h.
THE THREAT:
http://www.abc.net.au/stateline/nt/content/2006/s1736723.htm
NT COUNTRY LIBERAL PARTY:
http://notes.nt.gov.au/lant/members/Member...&Expand=1#1
NT TERRITORY LABOUR
http://notes.nt.gov.au/lant/members/Member...&Expand=3#3
NT INDEPENDENT:
http://notes.nt.gov.au/lant/members/Member...&Expand=2#2
  • 3 weeks later...
NT members of parliament vote on a 110km/h maximum speed limit this week.
If you don't wish this to happen, you *must* now ring and make contact with your local MP and tell them how *you* want them to vote at the time.
Edited by Keepleft
Cant see a speed limit of 110 happening. Very dangerous for a government to try and bring this in, going to be very hard to Police too. I would suggest that they will put a speed limit of around 140 and police it fairly loosely.
there isnt enough cops in the nt to try and police that lol
id still get on it,
everyone in the NT, anyone that has ever used these roads, should contact their MP,
dont let em do it.
a losing battle i would think ,,, its only a matter of time before this is implemented Australiawide...
Dont Worry about Policing it ..I am sure you will be introduced to the elustious Seniour Cunstable camera....
end of an era which is sad ....
  • 4 weeks later...
NT's speed derestriction is no more.
NT's NEW maximum rural default speed limit is 110km/h.
Some key NT highways are to have signposted 130km/h speed limits.
Other changes are a demerit points system based on the national model, and increased fine levels for speed and other offences.
http://www.saferoaduse.nt.gov.au/changesataglance.html
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
