Hi,
I live in Huntsville, Alabama in the US. I will be importing an R32 soon and want to know which would be a better car. I plan on, if I get the GTS-t, putting in an RB26DETT and eventually getting it up to GTR looks. I will primarily be drifting and heading out to the local drag strip. Which car would be a better buy, an R32 GTR or an R32 GTS-t? The GTR would cost me more at first, but will be AWD. The GTS-t would cost me less at first, and I can upgrade in stages, but will be RWD. I assume that having it RWD would be better for drifting, as AWD is inteneded to reduce traction loss, thus hindering ability to drift. However, I have read that with the GTR's AWD system, it only gives the front wheels power if it detects loss of traction in the rear wheels, and it can be locked in either AWD or RWD modes. Is this true? I would just like some simple advice on the subject.
Thanks
Mazikowski
EDIT: Just on a side note, I am about 6' 2" tall (so around 2m?). How would headroom in the car be for me? Would it be overly tight?
Edited by Mazikowski
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/
well it really depends.. if your going to use it more for drift or drag.
it will be ALOT cheaper to go the route of the GTR. Running conversions and doign things in stages will cost you an arm and a leg in labour/time/parts
plus.. who doesnt want a gtr :P
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2483860
Go the GTR! You can easily turn off the AWD by pulling a fuse or putting in a switch to turn it on or off.
It will be more expensive initially but you will spend more to get the GTSt to anywhere near the same dynamics in the long run.
If it does not have a sunroof you should be right height wise or you could fit lower seats if not.
Thought you guy's could not have Skyline GTR's there in the land of the free :P
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2483956
well, you cant import them really because of laws in states with major ports, but if you import the car w/o engine + engine separate, it can be done, just assemble it in the destination state and off you go... besides, it helps to have some connections :dry:
I should be able to get a GTR for around < USD25k or a GTS-t for < USD15k
plus.. who doesnt want a gtr :O
this is true... OH HOW TRUE THIS IS!!!! lol, sorry, had to get that outta my system
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2484197
If it is SPECIFFICALLY for drift, I'd go GTS-T. Lower purchase price, less weight (AWD hardware is HEAVY!), cheaper to replace parts and body panels (probably).
If it's a powerful multipurpose drag/track street car, I'd go a GTR.
I'm 6ft4 (with a heavy build), and I fit in my R32 GTS-T just fine. But for enthusiastic driving, I'd budget for a new drivers seat and steering wheel - the standard items are under and over sized (respectively) and are pretty much useless for people my size! The R32 GTR seats are apparently much better, but alas I have never driven one and hence cannot comment.
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2489230
Alright, thanks for the info on sizing. I will most likely be using it for both and maybe even some... I guess it would be like circuit? ... racing. Knowing that I can switch between AWD and FWD with a switch ( gotta install first, I know ) makes me wnat the GTR, a bit more power and better car for the most part. Now, to get the money >_<
Thanks
Mazikowski
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2492245
Id go the gtst personally, cheaper parts and parts are easly found. with the extra money you will have left if you bought a gtst, you could put it back into your car. dont let the GTR badge fool you I have seen plenty of gtst beat gtr in races on the street and personally, there's not substitute for hanging that arse out when you feel the need to. :O
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2492712
why would it be less expensive? I would end up putting an RB26 in most likely.
I will have to do some more research into it, but I still have a while to go before I would be fully deciding.
why bother with the rb26, go the rb 30, with rb25 top end, its stronger and can produce big hp. and go 1 big single turbo rather then twin turbo.
with the bigger engine, and reduced weight (not having a GTR) = :)
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2493346
but how hard would it be for me to get a 30 with rb25 top end? Like I said, It will take some research... thanks for the advice all the same
::EDIT::
Although it has a larger displacement than the RB26DETT, maximum possible horsepower is less, as the RB30 block lacks the RB26 block's internal cast-in bracing, and consequently cannot rev as high due to harmonic issues at ~7500RPM. To compensate, the RB30DET produces more torque at lower revs.
from http://en.wikipedia.org/wiki/Nissan_RB_engine#RB30
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2495813
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
