Hi,
I live in Huntsville, Alabama in the US. I will be importing an R32 soon and want to know which would be a better car. I plan on, if I get the GTS-t, putting in an RB26DETT and eventually getting it up to GTR looks. I will primarily be drifting and heading out to the local drag strip. Which car would be a better buy, an R32 GTR or an R32 GTS-t? The GTR would cost me more at first, but will be AWD. The GTS-t would cost me less at first, and I can upgrade in stages, but will be RWD. I assume that having it RWD would be better for drifting, as AWD is inteneded to reduce traction loss, thus hindering ability to drift. However, I have read that with the GTR's AWD system, it only gives the front wheels power if it detects loss of traction in the rear wheels, and it can be locked in either AWD or RWD modes. Is this true? I would just like some simple advice on the subject.
Thanks
Mazikowski
EDIT: Just on a side note, I am about 6' 2" tall (so around 2m?). How would headroom in the car be for me? Would it be overly tight?
Edited by Mazikowski
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/
well it really depends.. if your going to use it more for drift or drag.
it will be ALOT cheaper to go the route of the GTR. Running conversions and doign things in stages will cost you an arm and a leg in labour/time/parts
plus.. who doesnt want a gtr :P
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2483860
Go the GTR! You can easily turn off the AWD by pulling a fuse or putting in a switch to turn it on or off.
It will be more expensive initially but you will spend more to get the GTSt to anywhere near the same dynamics in the long run.
If it does not have a sunroof you should be right height wise or you could fit lower seats if not.
Thought you guy's could not have Skyline GTR's there in the land of the free :P
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2483956
well, you cant import them really because of laws in states with major ports, but if you import the car w/o engine + engine separate, it can be done, just assemble it in the destination state and off you go... besides, it helps to have some connections :dry:
I should be able to get a GTR for around < USD25k or a GTS-t for < USD15k
plus.. who doesnt want a gtr :O
this is true... OH HOW TRUE THIS IS!!!! lol, sorry, had to get that outta my system
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2484197
If it is SPECIFFICALLY for drift, I'd go GTS-T. Lower purchase price, less weight (AWD hardware is HEAVY!), cheaper to replace parts and body panels (probably).
If it's a powerful multipurpose drag/track street car, I'd go a GTR.
I'm 6ft4 (with a heavy build), and I fit in my R32 GTS-T just fine. But for enthusiastic driving, I'd budget for a new drivers seat and steering wheel - the standard items are under and over sized (respectively) and are pretty much useless for people my size! The R32 GTR seats are apparently much better, but alas I have never driven one and hence cannot comment.
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2489230
Alright, thanks for the info on sizing. I will most likely be using it for both and maybe even some... I guess it would be like circuit? ... racing. Knowing that I can switch between AWD and FWD with a switch ( gotta install first, I know ) makes me wnat the GTR, a bit more power and better car for the most part. Now, to get the money >_<
Thanks
Mazikowski
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2492245
Id go the gtst personally, cheaper parts and parts are easly found. with the extra money you will have left if you bought a gtst, you could put it back into your car. dont let the GTR badge fool you I have seen plenty of gtst beat gtr in races on the street and personally, there's not substitute for hanging that arse out when you feel the need to. :O
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2492712
why would it be less expensive? I would end up putting an RB26 in most likely.
I will have to do some more research into it, but I still have a while to go before I would be fully deciding.
why bother with the rb26, go the rb 30, with rb25 top end, its stronger and can produce big hp. and go 1 big single turbo rather then twin turbo.
with the bigger engine, and reduced weight (not having a GTR) = :)
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2493346
but how hard would it be for me to get a 30 with rb25 top end? Like I said, It will take some research... thanks for the advice all the same
::EDIT::
Although it has a larger displacement than the RB26DETT, maximum possible horsepower is less, as the RB30 block lacks the RB26 block's internal cast-in bracing, and consequently cannot rev as high due to harmonic issues at ~7500RPM. To compensate, the RB30DET produces more torque at lower revs.
from http://en.wikipedia.org/wiki/Nissan_RB_engine#RB30
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2495813
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
