Un-turbo A Skyline (re Turbo Later) <-- Read If U Want To Do The Same I Called Advan Performance.
For more clarity - because the sedan tailights are square-cornered where the coupe ones are round, and because the coupe boot lid doesn't work on the sedan, the method to do this has been to cut the sedan bootlid/reshape that part where they are different. Plus more f**king around. There are old threads on here such as where it gets discussed and it hardly seems worth the pain.
So I have my cd009 installed in the car with the gktech relocation and I’m not entirely enjoying the shifter placement. I found the serial nine cd999 shifter relocation and although it’s pricey it looks to be a better fit. My question is with the trans in the car will I be able to just remove the old shifter bracket and install the new serial nine? To fit the gktech I cut the selector shaft will the serialnine work considering I did that? The installation is the main reason I’m hesitant on getting it.
Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
