Arias Pistons 5 perfect one damaged
6 week wait from states for new one around $300
set of 5 a 1 bung one $750 0.5 over bore suit rb26 only
Aftermarket R32GTR only GAB shocks and springs semi low set 4 very good cond $450
like new harmonic balancer suit rb20 only new $300 sell $100
m in south australia near Tea tree plaza
please call 0415 344 630
Edited by SIR032GTR
https://www.sau.com.au/forums/topic/133974-assorted-skyline-parts/
3 ribs on all why would you ask if they are four ribs?
did nissan ever make a 4 rib? thats a pretty wide power steering belt ?
as far as kms who knows the condition is very good though and suits only rb20 det engines possibly non turbo also unsure
as far as indicators they look to be sold
ill confirm soon
Cheers Everyone
ill confirm soon
Cheers Everyone
Most r32gtst power steer pulleys are 4 rib for the hicas pump.
I think i see the confusion
The belt has four ribs and the pulley will suit so it has three ribs as such to match the four ribbed belt
it does fit a rb20det and had the same for alternator and air con etc
hope this clarifys
unknown kms in very good condition
centre bore clean and no cracks
When the guys put my car back together within half an hour a part of the valve guides
broke fell in and crushed between piston and head all fixed now but needed one piston only so
ended ordering 6 to save on time which did not in the end but now i have 5 spare dooh!!!
some one will need them and can order one to mate up a set from USA takes 4 weeks and
around $250 so full set of forgies will cost you $1000 instead of $1399
Edited by SIR032GTR
  • 1 month later...
  • 2 months later...
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
