hi everyone,
took the car through regency today. all was good except for the shimmed diff and less two child safety restraints, the ones that go over the speakers on the parcel shelf.
i was just wondering if anyone had a spare standard diff lying around for a r33 gts25t?
and if anyone wouldnt mind unbolting their child restraints and going without them for a fortnight or so, can you please let me know, i would really appreciate it.
if you like, i could arrange some beer or other alcoholic beverage for your generosity.
:dry:
https://www.sau.com.au/forums/topic/133995-can-i-borrow-parts-for-regency/
:O
Wish I could help but, a problem with the child restraint brackets is the bolts have to be welded on underneath.
hi everyone,
I have some restraints, not sure if they are a generic type, shitty location aren't they. Beer is a very nice liquid.
Thanks heaps for the response guys! theres a lot of love in adelaide.
nozila is taking the diff. Noz.. if you have time, ill try to hook up a hoist this weekend. are you free? its not set in stone, but i'll do my best.
re the child restraint brackets... i ended up just making my own that way i dont have to keep borrowing them whenever i have the misfortune of reverting the car to stock. many thanks to everyone who offered! warm feelings for you, i have.
sat morning im taking out my suspension. so should be free that arvo.
sunday working morning and free after bout 1pm. i hope that slots in with possibily making a hoist time and your time free.
cheers,
duc.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 馃槄
