post-1468-1158042745.jpgGrenade is a tuning parts company from Japan, producing wheels, suspension, aerodynamics, and exhaust for such cars such as the Skyline, RX7, RX8, 240SX.
Their GX-01 wheel has been out in Japan since its debut at Tokyo Auto Salon 2003 and has been gaining popularity here since Grenade began competiting in drifting events in the US. With big brake clearance, the GX-01 wheel is a popular choice for both street and track
$1400 bout 30% tread all round
Adelaide
17x9 all round
30+ 20+
Edited by skipppy
Nice rims, I'm interested. So these are the 8.5" wide ones? Are they +15, +20 or +30?
$1500 perfect condition with 2 ok tyres
Adelaide
come over on my chaser but wrong offset more likely fit r33 gtst gtr or r34 gt gtr
offset set for GTR's and GTST's are totally different, so which one are they?
Also i think Chasers use Holden style stud pattern, so they will not fit ANY Nissan.
man i wish people selling rims will actually find out the diameter, width and offset and pcd beforehand so it will be much easier for any potential buyers to decide
sure u are right roy cause u would of seen alot of this in the whole month u have been on SAU
Erin
ps dont have wheels in front of me as yet will have specs during weekend
5 X 114.3 17x9 all 4 +30
amazing rims not a mark on them bout 30% tyres yokohama's
NO OFFERS
cause i think they worth lot more would keep but ofset wrong
could handle large brakes
rm_man no trade sorry
Edited by skipppy
dude u live one street away from me walk down and have a look if ya want very pimp supprised they aint goin
r34 look with half the price and still japspec rims
let me know if you change your mind, there'll be a bit of cash your way too!
  • 3 weeks later...
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
