Advertising this for a mate.
17" black and red advan racing wheels.
Set of 4.
Straight off his skyline.
Needs new tyres
Some scratches but can be repaired.
$1200 or make an offer.
All offers will be considered or may be willing to do a swap.
Contact chris on 0431987481 with any questions, like i said they are his wheels not mine.
http://www.teamloose.com/index.php?act=Att...ost&id=1345
http://www.teamloose.com/index.php?act=Att...ost&id=1346
them links should work for pictures.
https://www.sau.com.au/forums/topic/134005-17-advan-racing-wheels/
no idea sorry, it is really shiny metallic red and then the black in the middle, still as they came from new i think so whatever the normal finish was new.
also wheels are 17x9 rear and 17x8 front with 35 offset
Edited by VKYOOT
Are the rears +38?
Hey guys,
yea im located in geelong, i can post anywhere in australia if you want but you will have to either organise the wheels to be picked up yourself or you can send me the extra $ for postage if you want me to organise it for ya.
the front wheels are 17" x 8" with a 35 off set, the backs are 17" x 9" but i am not sure of the off set, i assume it is exactly the same as the ones on the front. il check them in the morning and get back to ya's on it.
anyone would like to take them this week i could probably work out a better price for them.
cheers.
chris.
cheers.
chris.
Offset for the rears won't be the same as the fronts as this rim wasn't released in a 17x9 inch with a +35 offset, only 22, 38 & 42. I reckon it'll be 38
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
