  • Replies 41
Blitz Bov.... Tried for three months to get an adaptor plate to fit where the stock one was.... NO GOOD. No one had or could get one. So i had to get my mechanic to Fabricate it on to the pipe leading to the Throttle body. (under the pod). It cost a bit to do it, but it sound's great and looks nice.
I'd show a photo, but i dont have a digital camera.
Cheers
Loz
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-261222
Well, thought i might of had some boost loss (i got worried when people spoke of "boost leak") But after some under bonnet testing (rev hard and watch valve) i noticed the "button" (copper release thingy) moved down furhter on rev..to seal the BOV . So i took it out for a hammer (foot to the floor) and it all seems fine.!!
Next is the Boost Guage.
and maybe the "Skyline" logo lit up in Blue....
Loz
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-261291
Cheers
Loz
I haven’t been able to find a adaptor for the Blitz my self do they actually make them?
I think I'll go for a GFB or Turbosmart pop off valve:)
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-261367
I used a Trust Type R BOV on my GTST. The BOV kit itself doesnt inlcude the adapter however Advan at Silverwater sell the adpater plates for GTS-T so they bolt straight on.
After using a Turbosmart and an HKS SSQV BOV I found the Trust to be a better unit and experienced less idle/stall problems.
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-262699
holy cow lozza...im not sure if all those series of blitz bovs are the same or not...i've got the same one..and from the look of ur pic..ur one is really really loose...are you sure its not leaking at idle?
unless ur screw has been changed....cause my one you can see about 3 threads after the nut which is about just right...
do u have probs with rev's when coming to a stop after hard run?
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-263342
The Mechanic's adjusted it to suit with the standard BOV unit connected as well. After disconnected the stock one and now just running the Blitz one... It's a lot louder.... but "seems" ok. After a good run, it does drop the rev's very low...for a split second, then it must seal and all is ok. It's hard to tell if the unit is not leaking... Logic tells me if it was leaking, I'd lose boost pressure on the guage... but it still show's the same ..7PSI... (yes stock i know..) So i guess I'm not.
As posted earlier doing a rough run in in the garage showed the brass thingy to push down further during boost pressure....(vacume change i guess)
Eventually when i get an exhaust and stuff fitted ill get a dyno tune, and they can check all that for me...
Cheers
Loz
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-263371
Guest SXU29T
ive had three blow of valves in my s15 since i bought it blitz super sonic s1, then a apexi dual chamber and how a blitz super sonic s2 i found that even though the s1 blitz was 2nd hand from japan of a s13 silvia their was no idleing probs or boost leak and had and awsome bark goes to show theirs nothing like japanese engineering!!! i have a friend who had a brand new gfb bov installed in his skyline it shit itself after bought 13000k's the piston jus kept seizin?//// then swapped my blitz s1 for the apexi dual chamber it was good but didnt really find its sound loud enough(riceboy) and it was a big& bulky mfuca in my engine bay, now i have a blitz s2 its awsome has a diff sound to s1 not as loud but fluters a high boost cause of the fluted design of the outlet. i can give u a contact of some one that can get u a genuine blitz mounting adapter for skylines for bout 30-40 bucks but his in sydney? and its 2nd hand?
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-289894
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
