I have got my hands on the latest release from garrett.
i need a 25mm spacer between the turbo and the manifold,
and i need to fabricate a dump pipe but apart from that everything i had for the gt30 will plumb straight
in. I picked the .82 a/r so i will be very interesting to see the results.
here's a couple of pics. looks good
Edited by dangerman4
  • Replies 151
sorry
i just checked and my bad.
8mm is the dump flange bolts.
the t3 base bolts are 10mm.
and yes once it is spaced away from the manifold there is heaps of room.
i will start taking some progress pics when i get home from work.
Is this the internally gated T3 housing that Garrett have been promising all year, and part of last?
What is the used unit beside it? It appears to have a Garrett logo on the compressor housing too.
And most importantly, can you post up the CHRA ID tag number too please?
I'm going to be interested in the progress pics.
cheers
cheers
Yes very interesting , hope they are available in quantity !
Dale the CHRA number would be the same for any cartridge with the same comp/turbine so its the complete assembly or unit number you want . Something worth noting is the part number stamped on the side of the exhaust housings mounting flange in the second shot . This would almost certainly be the turbine housings part number .
What I want to know is can these housings be grafted onto the GT37R cartridges because they have the potential to be better than the GT3540R cartridge for the larger/est RB - just need a suitable exhaust housing .
Cheers A .
Edited by discopotato03
Awesome news!!!!
Out of curiosity.... :(
Do they have a .63 internal gate gt3540?
Hi all , I got to look at a couple of these this afternoon - yep .63 and .82AR ratio .
The Garrett part numbers for the housings themselves (according to the packaging) is 771300-5 for the .82 and 771300-6 for the .63 .
The waste gate flat valve looks to be the same size as the IW GT28 housings and there is room for a larger disc as well . Doing a "high flow" on this valve is common practise on souped up XR6T's so no reason why these could not be modified the same way . BUT - always that but - the greater the area of the disc the more area exhaust manifold gasses under pressure have to work on to try and force it open . I kid you not and don't laugh , I've seen people using what looked like old bed springs trying to keep this valve shut .
The rule is if you run high boost pressure do everything you can to have the exhaust manifold pressure down somewhere near inlet manifold pressure . You don't need massive exhaust manifold pressure to drive the turbine just sufficient gas velocity by thermal expansion .
Back to those housings , Brett at GCG has I think five of each AR size ATM so be quick if you need one soon . Had I been better organised I would have had some pics but no doubt they'll turn up .
Cheers Adrian .
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
